Other shooting functions
Temporarily changing the shutter speed ([Reg. Custom Shoot Set])
This method is convenient when you want to change the shutter speed temporarily, such as to shoot an electrical scoreboard* as a note in sports photography. This method is also helpful for changing settings other than the shutter speed temporarily.
Assign the setting to a key that you can press and hold while shooting images.
* The characters on the scoreboard will be partially broken if you capture it at a high shutter speed.
| Advance preparation |
| Shooting | Shoot sports scenes at a high shutter speed such as 1/1600 second. Press and hold the assigned key to switch the shutter speed to 1/60 second only when shooting the electrical scoreboard. |
How to turn the brightness level/overexposure indication on or off (Zebra)
The camera displays a zebra pattern over part of the image if the brightness level meets the IRE level that you have set. You can turn the zebra display on or off quickly.
| Shooting | You can turn the zebra display on or off by pressing the assigned key.
How to shoot telephoto images by changing the angle of view (APS-C/Super 35mm)
Although this camera is equipped with a 35 mm full-frame image sensor, you can intentionally shoot images in the APS-C size to make the angle of view narrower, allowing you to obtain the same effect as a telephoto lens without changing the lens. Although the pixel count and file size become smaller, you can shoot RAW images or select a focus area, unlike with the digital zoom.
You can set this function from (Shooting) in MENU. However, it is recommended that you assign the function to a custom key such as the C4 button if you will be using it frequently.
| Shooting | You can switch between the 35-mm full-frame image size and the APS-C-equivalent size by pressing the assigned key. |
