ILCE-7RM6
    Continuous shooting speed boost: Function setting methods
    If you assign [Cnt Sht Spd Bst w/ Hold] to a button in the custom key settings, you can temporarily perform continuous shooting at a specified speed by pressing the button.
    When shooting with continuous shooting speed boost, the (continuous shooting speed boost) icon is displayed on the left side of the screen.
    Continuous shooting speed boost icon displayed on the left side of the screen
    You can choose how to use continuous shooting speed boost according to your shooting style by assigning it to a custom key.
    You can choose between two options when shooting only with continuous shooting speed boost, [Cnt Sht Spd Bst w/ Hold] or [Cnt Sht Spd Bst Toggle].
    Setting procedures
    Select MENU → (Setup) → [Operation Customize] → [Custom Key/Dial Set.] → (select desired key) → shooting tab → [Drive Mode] → [Cnt Sht Spd Bst w/ Hold] or [Cnt Sht Spd Bst Toggle].
