creators' cloud
    Remote Camera Tool
    Interval Timer Shooting
    Interval shooting is a function for taking repeated shots automatically according to the specified shooting start time, shooting interval, and number of shots.
    We recommend that you check the images periodically during interval shooting.
    1. In the Device Selection Window, select [Tools] → [Interval Timer Shooting].
    2. Set the shooting start time and shooting conditions.
      Interval Timer Shooting settings window.
      • Capture start
        Start capturing immediately: Add a check mark to start shooting immediately.
        Start capturing after the specified delay: Add a check mark to specify the timing of shooting.
        Enter a time to start.
      • Capture interval
        Select the groups for which interval shooting will be used and enter the shooting interval for each group in minutes and seconds.
      • Capture duration
        Continue capturing until you press the Stop button: Select this item to continue capturing images until you click the [Stop] button.
        Continue capturing for the specified duration: Select this item to continue interval shooting for a specified duration, and enter the desired duration.
    3. Click [Start] to begin shooting.
